1 - 4 of 4 Posts
If you hook my phone to the ipod cable does it ring through the speakers or if you're using the map/gps do you get turn by turn thru the speakers?
I haven't had the phone ring thru but the turn by turn will over ride my Pandora radio and come thru the speakers.
Yes to both things. At least with an iPhone. I hear when it rings (assuming it isn't on vibrate) and use the gps all the time to give directions.
Not sure what phone you have but it may vary. I have an iphone 6s plus and use a 30 pin to lightning conversion cable to make it work. Also seen iphone 5 and 5s work.
My iPhone 5 if you don't have the ringer on silent/vibrate it will ring through the speakers. The GPS will give directions through the speakers as well whether ringer is on or off. It pauses the pandora when GPS instructions are given and then resumes playing
1 - 4 of 4 Posts
