1 - 20 of 39 Posts
I Love it!
Big Steve , your bike is awesome , brings tears to my eyes just staring at it .... BEAUTIFUL ! cheers
NICE!!!! this is on my "to-do" list.
Did you lose a lot of cornering performance when you lowered your front triple tree?
Damnit Steve!!! Now I've gotta hunt for a headlight! Because my mind is made up now. That's way cool Jr. thumb up
SteveO when you wired your headlight up what did you do? 2 light bulbs in the old one only one in the new... I am thinking of using both power wires to the one new wire. Help me out bro. Did you get your highbeam light to come off on the cluster?
That's a nice lookin bike bud. Love the front wheel!
Dealer installed it when I bought it
They had several loose connections and it burnt the the socket up.
Took it back and it blew fuse on way home.
Took it apart and you could see the shitty job they did so I cleaned it up and all was good.
Problem is that when socket melted it left a gap for air and moisture to get in and kept burning bulbs. So I have taken it off untill I get HID
I have to asume that the gap will not affect the HID install.
As far as how it is wired you just have to find high beam and low beam. I would have to look to be sure.
So my issue is the HB light had 2 bulbs now my judge just has the one... What do I do with that? New connection has 3 prongs. I am assuming that power from low beam goes to one prong and power to high beam goes to other. And obviously the ground goes to ground.
...So I have taken it off untill I get HID
I have to asume that the gap will not affect the HID install...
Guys, the Judge headlight HID kit project is dead, at least for now. It turns out the bulb does not fit through the smaller hole in the plastic cover that closes and holds the bulb in place. The fella testing the kit for me had initially tried to run it without the cover in place, but apparently the bulb works its way lose if done so.
Where did you get the headlight? I have been looking at the 2014 highball headlight and it looks the same as the judge headlight...anyone tried swapping 2013 HB for a 2014 HB headlight?
1 - 20 of 39 Posts
