1 - 2 of 2 Posts
Had the bike apart to powder coat a bunch of parts. Replaced the signals with a new LED setup (the old LEDs worked just fine). The only thing done differently is that the new lights came with a running light wire (ran to the license plate light) and signal wire (ran to signal). I have tried disconnecting the running lamp portion and it doesn't make a difference.
Now, the relay for the turns just buzzes and won't provide power to the lights. I guess my powder guy found a site that said someone replaced their relay with a Ford part, but didn't list the Ford part #.
Any clue what's happening? Need to get this back together like yesterday :confused:
Discussion Starter #2
Well, I sort-of figured it out. I had the ignition on but lights won't work unless engine is RUNNING.
I would guess this is a bad voltage from the battery, but she fires up without a hiccup. Guess it doesn't matter if they don't work without it running, but still kinda odd.:confused:
1 - 2 of 2 Posts
