1 - 4 of 4 Posts
I have a 2014 Vegas 8 ball, recently replaced front turn signals for leds now rear turn signals don't work break light does works (turn signals are on the break light not oem) and horn and headlight also work. Any insights of what could be the problem.
If they are not OEM they are likely not wired correctly.
CANBUS bikes can be weird with turn signal or brake light changes. My 2012 has it, not sure about steel frames but it is likely.
Reactions: NAB
You need a mechanic that is good in 12-volt wiring.
LED's are polarity sensitive. Check that with a meter. The wiring to one of my lights was reverse of the wiring diagram. Does it need a ballast resistor on that model?
1 - 4 of 4 Posts
