Hey Kevin....Can you set the TPS on these up with a digi multimeter or do you have to have the Digi wrench?These bikes are not perfectly counter balanced. Some imbalance was left in to give the motor some "feel". Not sure how much vibration you have, but a little is normal.
As to milage; the first thing needed to be done is a throttle body cleaning. If it still persists then the TPS adjustment needs to be looked at
Requires the Digital Wrench programHey Kevin....Can you set the TPS on these up with a digi multimeter or do you have to have the Digi wrench?
I know this is an old thread, but the image of this guy "strapping down" his engine is hilarious! :ltr:One of my friends has a 2008 hammer that was shaking real bad. He tried everything and the dealer showed him how to strap it. He took a winch strap like you tie motorcycles down with and ran it over the back jug and under the bottom of the frame than winched it real tight. Worked like a charm and it doesnt look that bad. Actually it looks pretty cool kinda like those straps you see on dragster engines. If it gets loose and starts to vibrate he just gives it a click.
yeah had to laughI know this is an old thread, but the image of this guy "strapping down" his engine is hilarious! :ltr:
The dealer must have been "Goober's Quick Stop/Victory/and Tractor Supply Store"....![]()
