Hi all - new to forum and Victory. Have 08 Kingpin Tour with 1500 miles. Changed oil at 500 to Torco 20-50. Seemed to quiet things up a bit. Recently started hearing a 'dry bearing' noise maybe from clutch. Sounds similar to a clutch throwout bearing going out in a car. Only makes noise under throttle, goes away on compression and when clutch is pulled in. Checked belt alignment and it is true on both sprockets. Does not make noise with rear wheel off ground. Seems to be getting worse. I'll take it to the dealer, but was wondering if anyone else has had similar issues or thoughts? Thanks!
