1 - 11 of 11 Posts
Ok, this is new terminology for me. I did some searching on the forum, but I don't get it...what does preloading the shifter mean? I've seen many statements that say this leads to smoother/quieter shifts?
I pull throttle down, pull the clutch, shift. I didn't know that was an option.
Thanks
Adam
It means lightly lifting up on the shifter to put the components under tension before you actually shift. Takes the slack out of the shift components and makes for a smoother shift (in my opinion).
So something like this?
Pressure on shifter
throttle down
clutch
shift
You're getting closer spyshot. Two more things will help: 1. Minimal movement of the throttle. There's no need to snap it back to the stops. 2. Adjust the shift lever downward so that when you slip your boot under, it partially takes up the slack. that give your foot more leverage.
thanks! I'm learning how to ride a motorcycle all over again!
Next lesson....Push left to turn left. Push right to turn right. :)
That tight of a shift lever adjustment could cause the shift ratchet to fail to reset between gears from time to time.
Key word; partially. I have 38K on my bike and its been adjusted that way since new. I ride a lot of twisty roads and do a lot of shifting - so far so good. From what I see on this forum, methinks the 2011 and older transmissions have fewer frailties.
I dunno about that. I've got 122,000 on mine, ride twisties when I can, and I never do any of that stuff.
Smooth shifting on the Victory crashbox, kind of an oxymoron.
Its never too late to learn. :grin
1 - 11 of 11 Posts
