1 - 3 of 3 Posts
Does anyone know if this shock for, say, the kingpin or Vegas fit the v92c? Th pictures of the shock look the same as the oem shock, and mines bout done for. Don't want to drop damn near $500 for a shock that won't fit, but the factory shock is done for.
If anyone can get the factory part number off their shock, I will try to find the part number on mine. If they match, then I know the progressive shock will fit. If not, then, **** :(
just looked at the stocker I took outta my 2010 Vegas and part numbers 1542391
Provided they're same length eye to eye and bolt holes same and there's physical clearance then any shock would get you out of trouble.
The Progressive is a mighty fine shock, can't the makers of it tell you if it'll fit straight onto yours?
Thanks for getting that number, I haven't called or emailed them or anything yet, when I get a chance I will. Just wanted to get a head start on the research I guess you'd say
1 - 3 of 3 Posts
