1 - 15 of 15 Posts
Changing my CCT back to OEM exhaust headers and need to pull the oil filter.
How much oil will I lose when I pull it? WD video says just a couple TBS but I don't know if his oil was already drained.
That's right -- maybe a few tablespoons, at most. I did it in late December. My bike was on a level floor, on its side stand.
What aftermarket set up did you have and why are you changing back? Problems with the one you are using? Noisy? just curious.
why do you need to pull the filter? i just pulled my stock setup off and never pulled the filter
Bike I bought had a ghetto 2 in 1 mod of OEM where crossover tube was cut and capped and right muffler was completely hollowed.
What a godawful racket. I don't want to pull my front header tube so goal is to install the crossover section with front tube in place = have to pull the filter.
Might not work, but gonna try.
i pulled my complete system, didnt touch the filter, but you may want to loosen the front headpipe, i couldnt quite get the rear pipe off till i loosened it up, it helped. good luck the connection at the front rear headpipe was a pain! shoot a little wd or something on it and lots of wiggling!!
When I pulled my stock pipes off. I took the filter off. It only looses a little oil and I makes life much easier. It only takes a second to pull the filter. It wasn't even enough lost to register on the dipstick. To me working on that exhaust is enough of a hassle to have to work around the filter.
gotcha, i didnt even notice if the filter was in the way. mine came off just fine, as far as that goes
Put a 2x4 under back tire and loose none
Not done with the job yet, but the (2nd hand) replacement center section with crossover is bolted in place. Didn't have to loosen the front flange bolts. It *just* slid into place and had to have the wife do a bit of prying at one point but it's done.
I did apply a very thin film of moly-grease to the slip joints and things slid back together without much trouble.
cool! but like i said i pulled mine off without pulling the filter, didnt loosen the front header till the rear was almost off, loosened it up and it popped off. i was pulling the front header anyway, but didnt have to.
Just dawned on me - my exhaust flange nuts hand no washers of any kind under them. What type should I use?
no washers needed
i hear ya, but they didnt come with a washer
1 - 15 of 15 Posts
