1 - 20 of 28 Posts
94.54 rwhp and 110.75 rwtq
Mods are the Llloyds torque tubes, Slash exhaust, Lloydz timing wheel +4, PC5 with Autoune.
Cams are next!
Nice I'm looking forward to my cams and Dyno tune!
94.75 rwhp and 110.4 rwtq
Cams are next!
Lets see a chart so we can see air/fuel and where the peaks came on.
I've heard the timing wheel isn't very beneficial. What have u guys found with it? Being a long time drag racer of cars and engine builder I have found there is no v8 that doesn't benefit by advancing the cam. What about these v twins?
I'm from the same world as you-never advanced a cam-only retarded them-especially on blower apps.
I literally gained nothing-at least nothing worth noting. I couldn't grab the drg files to post but I'll get a printout.
Only thing I noticed was less popping through the exhaust on coastdown and between shifts.
Advancing the cam makes it build more low-end torque, while retarding the cam makes it build more high-end horsepower. Performance cams are designed to run 'straight up'. If there were an advantage to advance/retard it would have been incorporated into the grind from the outset. Usually, people advance or retard a cam to make an unsuitable cam more suitable for the application.
I've built n/a and nitrous motors. Haven't built boosted engines.... yet. Lol. But to my understand with a cam specifically for ur boosted application on a v8 u would still benefit by advancing it a couple of degrees. Moves the curve and better peak power. The only time I tried retarding a cam was on a n/a 500 inch chrysler wedge and it ran like crap!
I agree... somewhat. There hasn't been a motor i've built that didn't have a cam custom ground to my application. And anytime I have advanced the cam i've either seen gains on a dyno or better et's at the track. Granted... theres only so far u can go + or - before u can get in trouble or it starts to run like crap. I'm just expressing what i've found with v8's in a drag race application. Still learning about vtwins
From a side-by-side comparison, the Lloydz cams definitely have a (not sure the term that's used) wider profile, so they'd open sooner AND close later (granted I dunno if that was the intake or exhaust lobe I was looking at).. Even for a mild cam upgrade it was noticeable from a low-rez pic.
I'll be interested to see what Kyle has in store with his recommended mod he quoted me (VM1-DR cams, timing wheel, Lloydz filter). Very curious how we'll end up with the timing. I imagine he's got the combination memorized from experience.
Retarding the cam wouldn't help us for sure unless the rev limiter is bumped.
It is what it is-there is an all bike day coming up at one of the local tracks.
I think I'm gonna try getting this thing down the track-it will probably be slow cause this is my first bike ever-never riden a bike till now!
I'm thinking with a skilled rider it should run 11.9'[email protected] me, I'll be happy to run mid 12's.
I've yet to take mine to the track. I'm sure one day it will wind up there for a shake down pass. Definitely keep us posted. Mine is similar except I have the cams too. It will be interesting what it runs
the timing wheel advances ignition timing not cam timing. i gained noticeable response with mine, and from 4 degrees to 8 degrees was 2hp 3ftlbs.
Here is the graph, run 9 was with the timing wheel and autotune.
Is this on par with the mods? The bike has just a hair over 900 km on it.
cheers
Very flat torque nice wish mine was like that.
You'll like lloydz cams. Your power band will be larger.... not to mention you'll make more power
That's pretty much what I said. If you have a cam custom ground for the application it should run best 'straight up'. If you have to advance/retard the custom ground cam... maybe the grind wasn't exactly right for the application.
Again, advancing the cam will move the graph to the left... make it act like a milder cam.
Retarding the cam will move the graph to the right... make it act like a more aggressive cam.
Ok.. School pad and pencil out. Question:
So the term used typically on the Adj Timing Wheel is to "Advance the timing" typically some +2, +4, +6 amount.
Does advancing the timing on the wheel mean retarding the cam or advancing the cam?
..If I hadda guess, I'd guess retarding the cam. Did I win? cheers
Somebody in another thread was saying that it advances or retards ignition timing. I think this is wrong... but who knows, I might be wrong. Doesn't make sense to me that would be mounted to the cam pullies if it couldn't change cam timing. U can adjust ignition timing with a tuner
If u advance cam timing... it advances it... if u retard cam timing... it retards it. Lmao
1 - 20 of 28 Posts
