1 - 8 of 8 Posts
Anyone just remove the trunk lid on a CCT ? if so which bolts need to come out.
Looks like a 2 person job any way you go at it. One way looks as though the backrest would have to come off to get at the 8 bolts on top half of hinge. The other way would be what looks like a 10mm and 2 allen bolts, in the lower half of hinge. Either way you'll have to support the weight of the lid.
I don't know your end goal but on my Vision I found it easier to remove the top half at the hinges under the speaker covers. Just remember to undo the teether inside first. If I remember correctly I took off the rear backrest to expose the speaker cover screws. Then I removed those to expose the hinges. Wasn't really difficult and I did it by myself.
There is YouTube video that doctor witch place removed trunk lid doing rear speaker install.
My CCT trunk lid was replaced under warranty. They handed me the new one and I replaced it myself at home. I don't recall it being much of an issue.
ok question.. how many and which bolts did you need to remove ?
I removed my lid last year while working on my stereo. if I recall, it was just the 4 hinge bolts (2 per side) that held the hinge to the trunk body. Don't forget to remove the tether and be careful of the brake light wire.
Thanks Broggyr
1 - 8 of 8 Posts
