1 - 10 of 10 Posts
When I click get maps and then accept all trims should they apply to the current map and then zero out until i ride again? Reason i ask is cause i accepted trims and noticed the next time i clicked get maps before even riding, the same trim levels were still in place. I thought they were supposed to zero out after you accept all values?
you have to send the map I believe.
No. Do not zero them out otherwise you will undo everything you just did. They will change again up to 20% unless you changed this value in the software. Just save the existing map in case you want to back to it then accept the trims and ride.
when you accept them it asks if you want to put them to the map it zeros out the trims though doesnt it?
Plug in autotune... hit "accept all trims"... unplug autotune.
It's really that simple.
see i accept all trims and then hit send map, but when i go back to get map it still shows values in the trim tables. I thought they were supposed to zero out until your next ride, and then you would see values where it made trim adjustments?
after you accept trims does it ask you to apply trims?
when i connect mine i dont click get map, i open the pcv software then plug my cord in, then my map is already there, the screen is blank till i click on trims or whatever. i look at my trims then accept, then click to apply trims when it asks.
Another thought, I called tech support and they walked me through quite a few things. Good support in my opinion.
What Dtmmil said. ;)
1 - 10 of 10 Posts
