1 - 9 of 9 Posts
Quick question... My shifter pedal and my brake pedal both have some side to side play in them. I checked all the bolts and everything is tight so I'm not overly concerned. Is this just a normal Victory thing?
Seems to be a Vic thing. My XC and now my XCT has the same side to side slop. I'm sure that WD bushing works well.
they do , put them in mine a while back, the brake pedal wasnt that loose but my shifter was, much better now though!
if you go that route, before you put the bushings in, look at the hole in the shifter where the bushing goes, there needs to be a slight chamfer to the hole, if there isnt use a drill and just put a small chamfer in it. the bushing will most likely not sit flush with the lever and may not fit properly , i think most are probably chamfered, mine was not.
Thank you for the heads up dtmmil. I appreciate all the tips and tricks that make my life a little easier...
1 - 9 of 9 Posts
