1 - 8 of 8 Posts
Really nice job. Best of both worlds! Cause you know... with "her" on the back you're going to need the extra luggage space! :D
Reinforced
Decided to reinforce and lift up to keep away from fender. Changed the bolt to a longer one with hex head, its easier to tighten then put chrome cap on it. It seems to work good as long as I don't load to heavy maybe 20 lbs. max. It is very hard to get to line up and start the threads, its tight. Cost around 20.00 dollars in steel and bolts.
1 - 8 of 8 Posts
