1 - 20 of 78 Posts
Howdy Y'all,
I'm the new guy here. Don't have a bike yet. Father-in-law (He's a big Harley guy) got me interested in cruisers (I grew up on CBR's and Interceptors).
Long story short: I've heard the sales pitch on these Victory's and I have to say I'm sold for the most part. But I'm wondering, since I can't find any actual proof, if anyone has any dyno data comparing the latest Harley 96, 103 and 110 motors to the Victory 100 and 106.
Mostly it's hard to find the numbers on the HD bikes. I know the Victory website says 97/113 for the Hammer but I'm wondering how real that is. A comparison of HP/TQ to the ground.
Has anyone seen 0-60 times or 1/4 mile times comparing any of these? All the tests seem to gloss over this stuff. I'd love to see a nuts up comparison with all the data.
Okay, I guess that wasn't very short.
Help a brother commit to the new american motorcycle. :)
Victory or Harley
I ride a 07 Hammer S with a few internal mods. I have yet to run with any Harley that could stay in the same zip code including 110's. on a good day and a good lunch I will pull just shy of 110 mph in the 1/4 (Old School 1/4 / 4 telephone poles) in 4th gear at the new redline of 6500 before hitting 5th. Stock V-Rod will not keep up in the 1/4 This is real world numbers on the street. A good guess would be 115 hp 120ft just a guess though. I have run with Harley with a peace of paper stating thay have 100 hp to the ground but by 2nd gear it didn't mean much.
in the real world lb. torque is the measurement that
means anything, i would say the reason harley has a hard time is those # meaning torque is not even close, same old story push rod & lifters[ h.d. ] v/s over head cam [ vic ]
not bashing hd they are good bikes, as ive owned plenty, last one for 17 yrs. just got tired of working on it. facts are facts
steve
At the tire a stock vic puts out.....
05-07 100" 74HP/97Ftb
08-10 100" 74/95
In S1 trim
05-07 82/100
08-10 78/97
The 106 in the 09-10
Stock 78/97
S1 81/102
All of these are rear wheel numbers. the 97/113 are crank numbers, and off by around 14% on average. Up to 17% on a wide tire bike
Now for an HD let me see if I can post this graph. Nope so here are the numbers
96" Stock 66/81
96" with pipes, and filter 72/81
110" found in a SE bike 80/96
All numbers are from my dyno at work except the 110", and that came straight from the SE catologe
Just for giggles my bike pulls 105/116 with it's current set up
Discussion Starter · #5 ·
Thanks for the reply. What internal mods are you running?
Discussion Starter · #6 ·
08-10 100" 74/95
In S1 trim
05-07 82/100
08-10 78/97
Stock 78/97
S1 81/102
96" Stock 66/81
Hey Kevin, thanks for the feedback. What's up with the 07' having more than the newer version? Also, why isn't there more of a difference between the 106" and the 100" motors? It would seem an 07' 100" would be the way to go for the money.
Discussion Starter · #7 ·
08-10 100" 74/95
In S1 trim
05-07 82/100
08-10 78/97
Stock 78/97
S1 81/102
96" Stock 66/81
What all is involved with S1?
In 08 Vic dropped compression from 9.8:1 in the 100" to 8.7:1, and introduced the 106 at 9.4:1. Pretty much lost power all around. That said the 106 in S1 trim makes more power in the all important idle to 3500 range; then the peak would suggest.
An S1 set would be some type of pipe, or slip on, a vented intake cover, and a higher flowing panel type filter
Discussion Starter · #9 ·
Thanks Kevin. Do you know why Vic dropped compression in 08? What would the 106 be like with the old compression numbers? Is it possible to change that?
Up until 07 Vic was able to run the motors on the rich side, and the extra fuel would keep cumbustion temps down a good bit. In 08 the move to closed loop injection, and the leaner A/F ratio that goes with it. Meant they had to drop compression, or run to hot.
Adding a set of cams, and an intake along with the S1 will make the new bikes perform like the pre 08 bikes, and the 106" shines when given the treatment. Still not up to the earlier bikes with an S&S stroker, but 107+/107+ is not unussual with the right pipe
Discussion Starter · #11 · (Edited)
You're talking 107+ HP/TQ at the wheel right?
I'm looking at picking up a 2010 Hammer S. I really like the 2 into 1 pipe Vic offers. So with cams, this pipe and the intake, I'll be at a stage 2? Do I need to add a PCIII or anything else? Also, do you know what cam and how much that would run?
To get those numbers you need a set of Lloydz VM1 cams, intake, and a VFC3 along with the 2-1 pipe. Also with a 09-10 bike you need a set of cam carriers to bolt the cams in place. There is no STAGE configuration for this deal. You leave STAGE behind when you start adding aftermarket parts
Oh yea those numbers are real world. I wish the photo utility was easier to use here; so I could post charts from here at the shop
Discussion Starter · #13 ·
Wow Kevin you're a wealth of knowledge. Thanks. So what's all this do to the reliability of the bike and does this void my warr? What's the price tag on the cam parts/work?
The Diamond
I'm not as knowledgable as Kevin but I personally know of 3 different engines from 104 up to the lloydz 110 that have been nothing but bullet proof.
About the only way you will have problems is if it isn't built correctly.
Done over 60 of these conversions to 106" motors, and have seen ZERO reliability, or drivability issues. fact is the bikes run, and drive BETTER then stock, and MPG remains oretty much the same.
Parts run....
Cams $390
Carriers $450
Intake[Lloydz] $280[I beleive]
VFC3 $265
Labor all depends on who, and where it is being done. Myself I charge $500 to do the whole thing on a steel frame bike, $400 on a 08 Vision, and $600 on an 09 Vision. I fly all over the country one weekend a month doing "Cam parties", and have prolly done more of these then anybody including Lloyd
Discussion Starter · #16 ·
Parts run....
Cams $390
Carriers $450
VFC3 $265
Sounds like I'll be giving you a call once I get my bike. What's the best way to contact you and what's the name of the shop you work for?
I work at Polaris of Gainesville in gainesville Florida. My travleing thing is all me though. When you get close drop me a line here, and I'll give you my contact info
Discussion Starter · #20 ·
Sounds like a plan. Hopefully I'll be contacting you within a couple of months.
As I'm looking at the Victory website they state the Hammer S as having a 97HP/113 TQ version of the 106 with stage 2 cams. These are different than what you're talking about, right? If so am I correct in thinking the cams+mods you're suggesting would produce higher returns?
1 - 20 of 78 Posts
