1 - 4 of 4 Posts
When I use the rear brake light comes omn every time. When I use front only 1 out of 3 or 4. Checked connection but not sure if I am overlooking an obvious flaw.
perhaps the trigger in the lever perch is corroded in worn in some way? all I got for ya.
How could you tell if it was?
It's most likely the switch (Victory part no. 4110242) - You can tell because that's the only thing that could be wrong. A blown fuse is out of the question since it works sometimes.
It could also be a weak contact of the wire that runs from the switch, which you could test with a voltmeter. However, most likely, it's the switch.
1 - 4 of 4 Posts
