1 - 8 of 8 Posts
My light is completely out. I checked the relay and the fuse. They are good. Is it possible the LED burnt out? Any help would be appreciated.
It's an 05 Vegas.
I have an 05 KP with the same issue... Not sure what the solution is yet, hopefully someone can help us.
Did you check for power at the last connection before the light? Did you just add the LED or did it previously work?
look under fender for bad wiring.
Pull taillight and then hook power to it to see if light is burned out.
Make sure you have the right ground and power wires
I checked the power at the light and I couldn't pick up a reading. I think it was the way I checked it though. The rear taillight is stock. I am going to try to plug it on to a different area and see if it lights.
So I hooked the light up to a nine volt battery and it light up like a Christmas tree. I guess it's in the wiring somewhere.
1 - 8 of 8 Posts
