Joe, the shock holds air but its toast. Damn bike wallows when I go through the pass something terrible. I used to run through at 75 and 80. Now I stick to 55 with the semis. I sent a note to Traxxion. I'm interested to see what they offer.
Apparently they offers complete upgrades for the vision and cross country. I'm only interested in the rear shock however.
I just need to get my HOOPTIE to stop jumping all over the place
I think you will be happy with any aftermarket shock you choose.
They all seem to be an improvement in performance over OEM.
A few years ago I asked some folks who were quite familiar with both high end shocks and OEM's about performance and durability of the OEM's vs the aftermarket. Here is what I was told.
Oem shocks have to put durability first before performance.
The valving normally is not as sensitive as it could be made in an attempt to make the shim stacks and other components more durable. Long functionality is a priority above almost everything else to limit the OEM's liability.
Aftermarket shocks don't have to worry about these sort of liability issues and the internals can be more sensitive and at the same time less durable. The shims ect can be thinner and able to track better because a long life isn't as important as performance is, which is generally their selling point.
At the same time all shocks degrade with use because the oil breaks down in them with use just as it does in any other hydraulic damper such as a fork. Once the oil begins to degrade the performance of any shock either OEM or aftermarket falls off and to restore the shock to the original performance the oil must be changed and the internals inspected or the shock replaced.
I was told that you can buy Oem's and treat them as disposable items, tossing them when they start to degrade in a couple of years, cheaper non rebuildable aftermarket shocks and toss them when they start to degrade in a few years, or buy rebuildable shocks and pay to have them refurbished when they start to degrade in a few years. It's all a matter of personal preference and there is no right answer.
Anyway that is what I was told and it made sense to me.
Good luck shock shopping and do let us know what you end up with and how it works. Were all going to be looking for replacement shocks sooner or later.
