1 - 10 of 10 Posts
Hi everyone , I have a 2014 CCT and was wondering what the Torque values are for the 5 bolts on the rear sprocket, and the rear axle nut? Also should I use Locktite on these NEW bolts?
If I read it right the sprocket bolts are 55 ft lb. The axle nut is 65 ft lb.
Thanks for the info, do you know if the use of Locktite is recommended , and if so which strength?
Blue. Not red. It's not in the manual, but its not going to hurt either. Me, I would do it. These bolts have backed out on a few pple.
Checked manual. 71 lb is what diagram says. Locktite and I was taught blue if steel into aluminum, steel to steel red. The hub bolt should be a self locking nut.
Correct it is 71 ft lb torqued in a star pattern. Blue loctite won't hurt.
+1 on the service manual. Far as I know all the X bikes are same from start to finish.
1 - 10 of 10 Posts
