1 - 7 of 7 Posts
I live in a county that requires emission testing.
Does anyone know if removing the 02 sensors will result in an emissions test failure?
I have new exhaust on the way, and I'm wondering if I should completely remove the 02 sensors and cabling and plug the exhaust pipe. However, if i do this, I'm worried I'll fail inspection.
If that is the case, I'll re-install the 02 sensors into the new pipes. :(
Thanks!
I would think you will fail yes. Until i put the pcv in mine, mine ran better with the O2s connected anyway.
Sent from Motorcycle.com App
don't remove them just follow the wires and un hook them it will make the bike run a little richer.
There not the easiest to un screw
So I just realized motorcycles are exempt from emissions in my county, so I should be good either way. Thanks for the input though guys!
Then its up to you, unplug them see how it runs, you can always plug them back in. I had a lot of backfiring when i unplugged mine.
disconnected but not removed
on the TRat forum for triumphs a member highly regarded for his knowledge posted leaving unconnected sensors in the pipes will ruin them in time! Forchetto is always right, all members appreciate his lengthy but informative posts. i read whatever he says!
A Highly Regarded member over at TRat???? I have not posted there in 2 years. Either your information is outdated or I have been replaced by a new know-it-all.:ltr:
1 - 7 of 7 Posts
