1 - 2 of 2 Posts
Guys, I have an 09 Pin and I modified a factory plate mount, but not sure on how to remove the original from the bike.
I looked under the fender, and see only the 2 nut but not the others. Do I need to remove anything to access these?
Can I get some pointers.
Easy way to get to the two top ones are....
Remove fender struts
Remove seat
Unbolt fender bolts from fender support. With a friend....lift fender up to access nuts.
While your there.....move wire harness to one side and zip tie to fender support to prevent tire from rubbing harness in two.cheers
1 - 2 of 2 Posts
