1 - 11 of 11 Posts
Howdy... The fuel pump in my bike appears to have frozen up during the three years or so that it's been sitting. I'm assuming that the only way to access it is to remove the big triangular frame member that the pump lives behind (which the battery box mounts to)? And if so, any caveats about taking it off? Don't have a service manual and would be grateful for any tips, or if there's a less invasive way I can't see. Thanks much.
fuel.jpg here is what I hope will show you what you are trying to talk about..
1 1013242A6 TANK, FUEL, BLACK/STEEL GRAY 1 Usage
1 1013242A2 WELD-TANK,FUEL,CAL,BLK,GLD PIN Substituted by 2520253A2-SP 1 Usage
1 1013242A4 WELD-TANK,FUEL,CAL,P-301/P-266 Substituted by 2520253A4-SP 1 Usage
2 5132333 CAP,FUEL 1 Usage
3 7517723 SCREW 4 Usage
4 7556155 WSHR,(10)FL,10X2 6 Usage
5 2520147 HOSE-VENT,FUEL TANK (See Footnote) 1 Usage
6 7080829 CLAMP-HOSE,.375,BLACK(10) 1 Usage
7 7517725 SCREW,SOCHD,M5X10,ZPB 5 Usage
8 4010277 SENDER-FUEL LEVEL,SMALL FLOAT 1 Usage
9 5830193 GASKET-FUEL SENDER 1 Usage
10 5811878 GROMMET-RUBBER,FUEL TANK,FRONT 2 Usage
11 1253233 THROTTLE BODY ASM.(49 STATE MODEL) 1 Usage
12 7080894 CLAMP,HOSE,12-17MM DIA 6 Usage
13 5411803 HOSE,FILTER/MANIFOLD 1 Usage
14 2530031 FILTER,FUEL 2 Usage
15 7080795 CLAMP-HOSE BAND,5/8"OD UMP 2 Usage
16 5411799 HOSE,TANK/QUICK DISC,RH 1 Usage
17 7080790 CLAMP,HOSE,DBL.BAND 2 Usage
18 2520131 QUICKDISC,FUELFEED,MALE,TEE 1 Usage
18 1500199 O-RING 1 Usage
19 5411914 HOSE,TANK/QUIK DSC,MOD,LH Substituted by 5411929 1 Usage
20 2520136 QUICKDISC,,FUELPUMP,FEMALE 1 Usage
21 7080895 CLAMP,HOSE,16-22MM DIA 2 Usage
22 5411801 HOSE,QUICK-DISC/PUMP 1 Usage
23 7547120 NUT(10) 2 Usage
24 5211889-067 BRKT,FUELPUMP TOP,BLK 1 Usage
25 2520128 PUMP,FUEL 1 Usage
26 7547119 NUT, HEXHD(10) 1 Usage
27 7547118 NUT 1 Usage
28 5411802 HOSE,PUMP/FILTER 1 Usage
29 5411762 HOSE,FUEL,RAIL/TANK RETURN 1 Usage
30 1500199 O-RING 1 Usage
30 5131507 FUELLINE,QUICK DISC,MALE 1 Usage
31 5131506 DISC-QUICK,FUELTANK,FEMALE 1 Usage
32 2530028 FILTER,FUEL,HI-PRESSURE 1 Usage
33 7517405 SCREW (10) 3 Usage
34 1500198 O-RING 4 Usage
34 1253174 INJECTOR, FUEL 2 Usage
35 2520132 RAIL,FUEL Substituted by 2520191 1 U
Thanks, but I have a download of the parts manual. The picture shows how the fuel system fits together, but doesn't give any indication of the best way to access the pump for removal. I know where it is; just hoping someone here has changed one out and can confirm the best way to get to it with the least amount of aggravation.
Search tech section for user BBob and service Manual, im pretty sure he has a digital manual that should get you rolling. Careful ofthefuel disconnect at the base of the tank. Plan on cleaning your TBs while your in there.
Tim
Usually I just pull the battery out and remove the battery box. Saves a lot of aggravation.
BTW my shop sells replacement pumps for a fraction of what Victory wants.
Yeah, I'm planning to get in touch about the pump, Ryan, thanks. I've already got the battery box off- behind it is that thick-steel triangular shaped left-side frame member, with the fuel pump mounted behind ("inside") it. So what I'm asking is, anything special about removing that steel plate to get to the pump? Or just twist out all those allen bolts, and pull it off? Or is there a better way to get to the pump? Grateful for any help.
By the way, I apologize- meant to post this in the tech section. Mods, please move to that forum. Thanks.
Tim
Thanks Tim, but it looks like the oldest service manual is the '02-'04, and by that time the fuel pump had moved from inside the frame to inside the tank.
Re. the disconnect- what a joke! There was still a little bit of old gas in the tank which I went to drain, first thing, before working on the bike. Disconnect broke the first time I touched it (I guess it is 13-year old plastic, after all). Replaced it with a brass tee fitting from Lowe's.
Just remove the bolts and it'll come right off. Easy.
Yea I have heard the disconnect sucks! I will try to remember BBob doesnt have teh 99-01 stuff, sure thought he did. Hes got almost everything else rounded up for us... lol.. Good luck and let us know when your up and running! Ryan will get you hooked up with the parts, thats for sure. Safe ridin bud
Timthumb up
1 - 11 of 11 Posts
