1 - 15 of 15 Posts
I've been reading all over the place about removing the CATS but have not come across 2 valuable bits of info...
1. Does removing the cats void your warranty and if so, ae we talking all warranty or only specific components of it?
2. What specifically needs to be removed from the bike in order to get the cats out? (I have read how to get them out)
Thanks
I removed mine when I was running the stock exhaust, very easy upgrade. You will need a hole saw that just fits into the pipe, you will have to fab up an extension so you can reach the plates (there is 2 of them), pull the pipe off and drill them out. Will it void your warranty? Only if they can prove that drilling out your baffles caused any damage to your bike. The bike feels great after the mod, breathes so much better, do you have a fuel controller? If not unplug your O2 sensors....
Thanks for the tip on the 02 sensors.
I disconnected the O2 sensors on my 2012 CCT for 100 miles. I went from mild popping to ridiculous amounts of popping as well as losing about 2.5 mpg. I re-connected them after that ride. My bike is a 2012 CCT with a Lloyds air filter, Tri Oval mufflers and the Victory fuel map download.
For me and my bike, there was nothing good that came from disconnecting the 02 sensors.
I never had the popping with or without the sensors, but I lost a lot more than 2.5 mpg without them. I'm with you, though in the heat of the summer, the richness will allow the bike to operate a little cooler and may be worth losing some efficiency.
Thanks
Two cats in the pipes. One is located under the passenger foot rest on the right side. Remove the pipe and you will see the Cat.
The left cat is located in the cross tube next to the Oil filter. Remove the pipe and the elbow to access.
I tried the hole saw first.. bit of a pain in the A$$. I used a 3/8 drill bit and drilled a serise of holes around the edge of the cat. There is a sleeve between the cat and the pipe. . Then with a long nose pliers pulled the cat material out. be carfull it is very sharp. I used a die grinder to clean up the sleeve and reinstalled the pipes.
I have a Cobra power pro installed and also disconnected the O2 sensors. Very little to no popping hot or cold. greatly reduced the heat generated by the cats.
Sound just a bit louder throttle response a bit crisper. Fuel mileage about the same. Just did a 1400 mile ride to NY and back with a trailer behind. Work great no issues of any kind.
Warrentee... talk to Vic Dealer and he did not recommend it but he also sells pipes without cats too.... oh by the by drills them out too.
Cheers
Something of note... I used header wrap on the cross tube and areas under the ppassenger foot rests to further control the heat.
Riding on a 90+ humid day is very doable now... not roasting the chestnuts anymore.
Two things:
Cats mandated by Federal law (IE forced by EPA)
O2 sensors, mandated by Federal law (IE forced by EPA)
Cheers
Thanks Squatch ... I figgured you'd come thru with some details.
Why would you have to unplug the O2 sensors?
Jim
I'm guessing here but it seems to me that removing the cats causes a leaner burn. Disconnecting the 02s balances that coz just disconnecting them by themselves (no cats removed) causes a richer burn.
No worries,
With a good drill the whole process should take you no more than two hours.
Pull the bags, then the pipe on the right side leave it connected to the Elbow on the left and take the two off as one. easier to remove that way.
Glad I could help
Hey riding up to Banff and Jasper next year coming down thru BC and Kamloops, you any where near?
I live in Burnaby which is appx 4.5 hrs South West from Kamloops where I used to live for several years. Burnaby is next to Vancouver, BC
The local dealer yonder will remove the baffles and the cats but they also reprogram the EFI to the Stage 1 chip and charges $500 for it. $250 for the chip reprogramming and $250 for pulling the baffles and cats. I had another dealership say it puts you at risk of voiding your warranty if an inspector checks out your bike during a warranty claim and that you loose your mid-range power through the mod (with the bike being EFI and requiring the back pressure... I guess). Perhaps he was just trying to make a sale and is full of sh*t or there might be some merit to what he's saying.
Thats cool that a dealer will do the work up there.
As to loosing power... there has been a bucket load of discussion on that. I have removed mine and am very happy with the before and after... don't get wrapped around a couple of HP or Torques... Add the air filter and either a stage one or tuner and they are back.
Two things:
I'm in Texas and we have emissions testing in my county. I've never asked, but do bikes get this testing? If so, will removing cats and O2 sensors result in a fail?
1 - 15 of 15 Posts
