1 - 6 of 6 Posts
Ok,
I just bought a used 2013 Vision. The person I bought it from stated that he had the dealer change the function of the trunk running lights, into turn signal indicators.
I would like to change these to brake lights. Two questions:
1) Is this functionality possible?
2) If yes above, how to do it.
Thanks for any help.
Thanks for the link to the download. I have downloaded the file and reviewed chp. 19 electric but did not see anything that would help re-programming the trunk light functions.
I will continue to review and search.
first you have to figure out how its wired now. Then you have to pull it apart and see if there is dual or single filament bulbs
Got ya. I was assuming(we all know what that means) that is was programmed via a special sequence in the ECM. Know that I know it is a physical wiring/bulb item I can probably figure it out.
Thanks
there are six bulbs.
top two are run/brake/ turn.
mid two are run / brake only or turn only. they both turn off if braking and turn is on.
bottom two are run/ brake
1 - 6 of 6 Posts
