1 - 8 of 8 Posts
Needing an Electric Reverse Lockout Switch (relay). PN/2411220 located just in front of the hard saddle bag, left side.
This is a safety relay that restricts the forward gears and starting while the electric reverse is engaged
Circa 2011 Vision accessory
If it's just a relay a simple relay could be adapted for the purpose.
If you have the original now non functional relay, there might be enough info on the case to figure out what it is. Can you post a closeup picture of any diagrams or information you find on the case?
Discussion Starter · #5 ·
Plant Font Gas Tree Nameplate
I am suspicious that the original installed part #4012018 has been re-numbered in any replacement look-up as #2411220.
What Joe linked above looks to be same part in your photo. Can't get a better match than that.
Not sure what that module does without looking at the wiring diagram. It's probably possible to duplicate the functions. I feel same about the fancy turn signal modules.
1 - 8 of 8 Posts
