1 - 12 of 12 Posts
Hi was wondering i have the 2007 hammer stage1 flash and bike has been rich since day one.I would like to go back to stock flash and put a fuel controller on.Dealer says stock flash is around 200$ plus an hour labour.Why would victory charge for the stock download?
Go to another dealer. Unless Vic has recently started charging for a stock flash, mine were always free.
Ride safe.
If you are adding a fuel controller, you do not need to go back to stock flash. Keep the stage1 flash, and add the fuel controller.
Lloydz motorworks says 2002-2007 revert back to stock flash 2008 and higher dont need too.So i am just going by what is says on Lloydz website
Please note that it is ONLY necessary to revert back to a stock download when installing a VFC on 2002-2007 models. It IS NOT necessary on the 2008-later models. The downloads on the 2008-later models are lean enough that it does not drastically affect the tuning of the VFC
Oh, that's rigth, it's a 2007! :D
Stock map should be free though, as others have mentioned.
What kind of air filter do you have on it? Do you plan on upgrading the air cleaner?
i have S&S and the plugs are black black!!!i thought i had air leak but more air would make the bike run lean anyways i check intake as i hear the rubber gets cracked they are fine.No exhaust leaks cant figure out why the plugs are so black.thats why i want to go back to stock put on fuel controller and see how that works.I know the stock flash is really lean to pass EPA so i should not have to remove any fuel just add hopefully atleast that what i am being told
just a question...would he have to revert to stock if he were to add a powercommander V. On my newer model there is a map that has a stage 1 ecu flash integrated into it.
Hi was wondering i have the 2007 hammer stage1 flash and bike has been rich since day one.I would like to go back to stock flash and put a fuel controller on.Dealer says stock flash is around 200$ plus an hour labor.Why would victory charge for the stock download?
Tell us what your getting for mpg
Stage 1 flash should give you more gas. Why did you get the flash. Do you have performance air filter or exhaust.
Give some more details about your bike
swept pipes thunder monster baffles S&S air cleaner victory stage flash1 never kept track of mileage but seems like i am always filling it up plugs are very black and just looked at them and they are wets smells like gas maybe injectors are working right all the bikes i ever had were carburated so was not hard to figure out but ever since i got it the plugs have been very black
1 - 12 of 12 Posts
