how many are using this and are there any uoa's for this stright up
How many bucks does that cost ya? :ltr:I also rub mule deer semen on my chest before each ride don't know if it helps but it makes me feel better.
T6 is blended for use in Diesel engines which are a lot harder on their oil than spark ignition ones. Some of the additives in engine oils, and especially those for Diesels, are there to coat parts so there will not be a dry start up.The only thing that I would caution about the 5w at start-up is that it could cause your lifters to bled down and make some noise. Also, it doesn't lubricate better when cold because it's to thin, which could cause additional wear at start-up. If you don't put that many miles on your bike then a lot of things won't matter. Use what you want.
Beats rubbing it off your chin lolI don't know why people get so worked up over oil threads they are usually good for a few laughs.
I just switched to T-6 for the first time so for no problems, I also rub mule deer semen on my chest before each ride don't know if it helps but it makes me feel better.
You are backwards on that. The lighter the viscosity on the Winter weight provides better lubrication at start-up. A higher viscosity oil will actually cause oil pressure to build slower and cause excessive wear.The only thing that I would caution about the 5w at start-up is that it could cause your lifters to bled down and make some noise. Also, it doesn't lubricate better when cold because it's to thin, which could cause additional wear at start-up. If you don't put that many miles on your bike then a lot of things won't matter. Use what you want.
Actually, diesels in trucks are not that hard on the oil except for soot loading and fuel dilution. You will not have any soot loading in a gas engine but, if you have fuel dilution and it is not Turbo'd, you have a problem.T6 is blended for use in Diesel engines which are a lot harder on their oil than spark ignition ones. Some of the additives in engine oils, and especially those for Diesels, are there to coat parts so there will not be a dry start up.
No, When I was riding a stratoliner many people were having problems with lifters bleeding down when the engine cooled. The fix was to replace that 10w40 or 5w40 with a 20w40 or 20w50. I've only read of one victory rider with noisey lifters after start-up so it may not be a problem here, but I'll just stick with a 20w40 oil.
Something else to consider is the amount of cushion provided by the oil. I feel that 1/4 the viscosity ( 5w )would be to thin and do damage to bearings on initial star-up just because the bearing material could be touching. It would be like using a 5w10 oil in the bike only not damage as fast.
I'm certain you will post your oil analysis results. I'm interested in how this particular oil does comparred to oils that are intended/marketed for gasoline engines.Funny this thread started I'm changing out the T6 Saturday and sending in a sample. They (Blackstone) recommended 7500 but I'm good with 5000 and that's where I'm at now. Considering the factory recommends 2500 for my year I'm happy so far with the Rotella.
3rd and final sample.
Rotella is a Dual Rated oil for both Diesel and Gasoline provided it has the proper API for the application. You can't use just any oil in any engine, it must carry the proper API.I'm certain you will post your oil analysis results. I'm interested in how this particular oil does comparred to oils that are intended/marketed for gasoline engines.
Like it ...... Laughed out loud.....How many bucks does that cost ya? :ltr:
