1 - 1 of 1 Posts
Does not fit my 2011 Victoy Jackpot. The reason is the rear brake line, starter positive cable and a wiring loom are clearly in the way of attaching that rear boltup point. SO - I made a modification to it that fits like a glove now.
RPM Big Slash folks - listen up. Look at the pics
If you are installing these on your 11 Jackpot, you need to know this, maybe even the 12 and 13 models.
You can see where the oroiginal bracket has a slot to slide into that rear bolt. It will NOT pass thru that area due to the above. Pics says it all.....thumb up
1 - 1 of 1 Posts
