1 - 2 of 2 Posts
Just got my new 2013 cross country tour and went out on and around the vegas strip then went home. Couple days later with bike fest in town rode up and down the strip "once" stopped bike to get a water came back out and would not start? It only started after I goosed the throttle i guess to force fuel into it? Went home and in the morning it started just fine?? Temps where around 100? Help
Your bike doesn't mind 100°F weather. ;)
You might have had a bit of gas vapor block. :confused: On a hot day, as soon as you stop the bike, even though the engine is turned off, the temperature will continue to rise for a bit, as the cooling effect of moving air is removed.
Also double check your battery connections and make sure everything is tight. thumb up
1 - 2 of 2 Posts
