LED are usually X watt equivalent, which is to give an idea in brightness level, but actually consume less wattage. Dig into the specifications on it and it should list the actual watt requirements. If it is less than or equal to your standard bulbs then LED should be perfectly safe for your needs.
Check measurements as well because some LED bulbs can be larger than a standard bulb and might not fit your housing.
