1 - 4 of 4 Posts
Looking for a PCV map for an XC with stock cams; the Lloyds high flow air filter; and victory 210 performance slip ons. Would be extremely grateful to anyone that might have this map built on a dyno. Dez
Sense you have Autotune just about any map will be a good starting point. Take it for a ride about 10 min or more than come back home don't turn it off (if you turn it off autotune changes or lost you will have to redo ride) hook it up to your laptop. It will show you the changes autotune made to your base map. Now sense the map in your pcv is probably already saved on your computer just send the new autotune map to your pcv. Now you can go for a ride or turn it off. Do this several times saving your old map before sending each new one so you can go back if you like old one better. It will take a few times because autotune can only change a little each time. It's quicker with a Dyno but this works just as good and when you get finished you will have a fine running bike. You will have do this again anytime you add anything like pipes, airfilter, timing wheel or anything that makes a change to the way air flows though the engine. Have fun enjoy your new toys. cheers
I forgot that when you get back from your ride and are viewing your autotune changes they are called trim tables so after hooking up your laptop you click on trim table to view what changes autotune made. You have to go to map tools click on auto tune tables to except trims than you can save them to your map.
Ok adding a web address for youtube on using autotune.
Anyone have a map for a PCV that should work for this.
2013 XCT, LLoydz AF and Bassani Slip-on Exhaust.
I had my bike, with that exact setup, dyno tuned by Dynojet so they could post the map on their website. I don't know why it's not up yet.
My laptop is garbage but I will try and take a screen shot of it for you later tonight.
1 - 4 of 4 Posts
