This week I posted about my CCT dyno tune nip and tuck. Also that the next day, I had a small (2") puddle of oil under the shifter shaft seal. I'm not due for an oil change for another 1500 miles or so therefore I thought I'd hold off until then to replace the seal.
Today I removed the shifter arm lever from the shifter shaft and used a socket to tap the seal all the way back in. To stop the seal from coming out again I installed some aluminum crush washers between the lever and the seal. When I replace the seal at the next oil change, I may just leave those crush washers in place to prevent the new seal from coming out.
The aluminum crush washers I used were left overs from my Moto Guzzi bikes. They have an ID of 14mm , an OD of 22mm and they're 2mm thick. I think I used 5 of them to take up the room between the seal and the bracket.
