1 - 15 of 15 Posts
I've searched for couple of hours now with no luck so...
Anyone know who does/can rebuild the rear shock on a V92SC? Mine is leak fluid and doesn't seam to want to hold pressure. Thank ahead of time.
2000 V92SC
Middle Tenn
it ain't stock...
I have the same problem on my bike. Went to the closest dealer today (2+ hours) and the parts guy couldn't find a complete shock for it. It's been leaking for awhile now and the only thing I can find are used ones. Not a fan of used suspension parts
go to ebay don't think there is any rebuild kits out there
OK. Thanks for the info. Guess it will get a used one at some point.
2000 V92SC
Middle Tenn
it ain't stock...
Didn't get to this soon enough or I would have said something similar. Race Tech, Traxxion, Advanced Traction, GMD Computrack, and one more that I can't remember off hand are all excellent options that should be able to help you out. I've dealt with every one of them at one time or another with great results.
not a V92 but I'm just about to head up to the post office to pick up a Progressive 465 I've bought used off an Aussie member on here.
I got the disc manual and had a look, just wondering if theres any tricks and perks when swapping over the rear shocks?
I daresay it's time to lube the shock linkages while its apart too.
A moly grease I presume?
Also I don't have a lift table just a trolley jack, and also an engine crane for lifting motors in/out of cars, any tips?
Sounds like you could use the trolley jack to get the entire bike in the air and then use your trans jack to raise and lower the rear wheel as needed. A scissor jack should do it too.
Thanks mate...exactly what I've done:)
Borrowed a bike jack from the welding shop next door and got a mate to assist me, we jacked the bike up, undid all the nuts n bolts, top and bottom of shock and the two bolts on the C-link.
Removed the battery and fuse holder for easy access.
put my workshop trolley jack under the rear wheel and raised it till all bolts came free and shocky almost fell out!
I fitted the Progressive 465 that I bought off 'benm' and jiggled the bottom of it as my mate got the top bolt through then I let the back wheel down till the bottom bolt lined up.
NOTE.. had to source a longer bottom bolt as the Progressive is thicker at the bottom mount otherwise the original would've only been held by 2 threads of the nut.
Everything tight I took her for a ride as benm had it set up, rode real nice n smooth, joins in the concrete road that normally jar noisily were glided over!
Got home and Googled shock tuning on a few sites then jacked the bike back up took a fully extended measurement, also put a cable tie on one fork leg to see how much it rose when weight off.
Then a measurement on the ground with no weight but settled, then a measurement with me sitting on the bike.
Note I backed the rebound setting off to 1 as benm had it set at 5, the site said to back it right off when measuring.
A little arithmetic showed the preload within spec but as I regularly carry bags and a passenger and I dont wanna be screwing with it all the time I wound one more turn down on the preload which brought it to the upper level of tolerance and should drop back to middle with my light passenger.
Then I brought the rebound up to midway the 3 position with my trusty allen key.
Now the fun part!...a test ride to fine tune and have a tinker with the rebound to find a happy medium.
Progressive 465 is a vast improvement over stock.
And 'benm' is a good trustworthy bloke to deal with.
Time for a 2am test ride:)
leaving the cable tie on my fork-tube to gauge how far my fork compress under my normal riding.
May end up upgrading the front to match the rear if I feel it needs it.
Sounds like an excellent upgrade!
Sure is!...3.15 am and sitting down to a bowl of frozen yogurt.
just got back from a test ride and the verdict is good!
Rides real nice!
Rode all afternoon today , took the rebound damping up a notch to 4.
Handles better, holds a line nice and is measurably quicker through familiar corners.
Still to try with a passenger, should actually be better with the preload Ive dialled in.
factory shocks are a compromise
there is no way of knowing whose gonna ride the bike, 150 lb or 250 lb or more. they are built to a price point as well. i installed my Penske shock built for me with a motorcycle jack only, a bit of struggling laying on the floor but dooable. i noticed some sleeves involved are filled with needle bearings!!! it transformed my hard riding 13 hammer, easily adjustable as well, i even use the OE seat!! buy the best suspension parts you can afford, well worth it!!
1 - 15 of 15 Posts
