1 - 2 of 2 Posts
Anyone know where I can find a turn signal wiring diagram for a 2009 Vegas 8-Ball? Changed out the stock signals, the rears went OK and as soon as I installed the fronts I ran into problems. I may have defective front signal but I would like to have a quick look at a diagram also. Thanks
check out the search part of the forum but I had the same problem, the front right side is switch at the plug and the black wire is actually positive... if you wired it wrong you will need to order a new auto cancellation module
1 - 2 of 2 Posts
