1 - 3 of 3 Posts
Well now that the weather is finally warm enough again up north here I got to take the bike out this last weekend and it was great!
I have one little hiccup with the bike.
When I am going full throttle and I do a fast shift near 5k rpm, I let off the throttle and then when its in the next gear I go to give it a handful again and it has about a half of a second where it doesn't go.
Is this a common problem? I tried searching it but I didn't find anything.
Other than this the bike runs great and I can blip the throttle and it doesn't die or stall.
start looking at the PCV. If you haven't had the bike dyno yet go get it done. You setting are not right
Well I have done some tinkering with the PCV and tried a few different fuel maps and it is still happening. I have also tried adding 4 degrees of timing on the PCV and 0 timing map.
It seems to only happen when I get to high rpm
if I short shift, like 4,000 rpm or so it doesn't happen
1 - 3 of 3 Posts
