witch one would YOU put in your Vic
  • Total voters
    97
1 - 20 of 43 Posts
Last time I started a oil tread;
http://www.victoryforums.com/showthread.php?t=123098&page=2
And because of the good input of all you guys I started digging websites and need your help on making a decision a POLL if you like ?
In ASIA it is difficult to find Victory Oil, and after 7000 Km the Vic Oil degrades, I know this because every 3K oil-analysis,
SOOOOO see below all the oil available in Indonesia, no particular order, and asking for your experience with any of the below.
I hope you guys can shed some light, see below a short description and web-link and NOTE if there is no T6 stated on the website then we do not have it just the sites below are available in Jakarta.
Long story short; witch one would YOU put in your Vic
• AMSOIL
• IDEMITSU
• LUCAS OIL
• SHELL
• ROYAL PURPLE
• MOBIL
• ADNOC
• VICTORY OIL
AMSOIL
http://www.alliancz-intl.com/
http://www.alliancz-intl.com/divisions/divisions/automotive-2/motorcycle-oil/
1. 10W-40 Advanced Synthetic Motorcycle Oil
2. 20W-50 Advanced Synthetic Motorcycle Oil
3. Synthetic SAE 60 Motorcycle Oil
IDEMITSU
http://www.idemitsu-ils.com.sg/products/prodlist.aspx?CateID=7
1. Idemitsu 4T Max
10W40 SL/MA Fully Synthetic – NEW
2. Idemitsu 4T Max
10W40 SJ/MA Semi Synthetic – NEW
3. Idemitsu 4T Max Eco
10W30 SJ/MA – NEW
4. Idemitsu Extreme TOURING 4T
4T 10W40 MA Semi Synthetic
LUCAS OIL
http://www.lucasoil-indonesia.com/products-19-motorcycle-oil.php
1. Synthetic SAE 20W-50 Motorcycle Oil
2. Synthetic SAE 10W-40 Motorcycle Oil
3. Synthetic Fork Oil 5WT / 10WT / 15WT / 20WT
4. Semi-Synthetic SAE 10W-40 Motorcycle Oil / API SG / SF / CC / CD, JASO MA & JASO MA-2, ACEA A3
5. SAE 20W-50 Motorcycle Oil
SHELL
http://www.shell.co.id/id/products-services/on-the-road/oils-lubricants/advance/find-right-bike-oils/4-stroke-engine-oils.html
1. Shell Advance Ultra
For Shell’s ultimate protection and performance.
2. Shell Advance AX7
For high power and torque even under stressful conditions.
ROYAL PURPLE
http://adminxyz.com/royalpurple.co.id/product/view/2/5/5
1. High Performance Street Motor Synthetic Oil / include: 5W-20, 5W-30, 10W-30, 10W-40 and 20W-50.
2. Extended Life Oil Filters
MOBIL
http://www.mobil.sg/AP-English-LCW/carengineoils_id_motorcycle-oils.aspx
1. Mobil™ Extra 4T
Mobil Extra 4T is a high performance, semi-synthetic blend technology four-stroke motorcycle engine oil developed to provide boosted engine cleanliness and protection for all types of motorcycles and operation.
2. Mobil Super™ 4T 20W-50
Mobil Super 4T 20W-50 is a high performance conventional four-stroke motorcycle engine oil primarily intended for general use in all types of four-stroke motorcycles and engines.
3. Mobil Special 4T™ 20W-50
Mobil Special 4T 20W-50 is a general performance four-stroke motorcycle engine oil intended for lubrication of small four-stroke engines.
ADNOC
http://ezyinfotechbd.com/adnoc/?SingleProduct=17
1. 4T 4 stroke is multigame (20w 50) Superior lubricating developed specifically for motorcycle and 4 stroke gasoline engines working under severe duty conditions.
Application 4T-4 Stroke Engine Oil is highly recommended 4 Stroke motor engines such as Honda, Suzuki, Kawasaki, Yamaha and other motor cycles.
ADVANTAGES
1. Having stable viscosity both a low and high temperatures.
2. Prevents wet clutch slippage.
3. Excellent oxidations stability under exposure to high operating temperature.
4. Keeping engine clean and providing excellent protection against piston deposit formation.
5. Providing optimum protection against rust and keeping engine parts from wear.
6. Keeping motor engine operate much better so that transmission friction is made as minimum as possible.
7. Protect vital gear & clutch component to extend its service life.
You can create a poll so people can vote.
I vote name brand wet clutch compatible. Nuff said.
Oil ?
Personalty I would narrow the field by only including oils that are JASO-MA rated, than price, than available.
Also shear stability (Group III, IV, & V) will give longer intervals between changes. Hard to know without feedback from fellow users.
Some good reading comming our way.;)
witch one would YOU put in your Vic if you live here?
Good points see below all oils are for wet-clutch JASO Standard, MA/MA2 and I will add a POLL, and please note the price would not matter much as the transport from Jakarta or Singapore to our Island will be quite expensive,
• AMSOIL = wet-clutch / JASO Standard, MA/MA2
• IDEMITSU = API SJ & JASO MA
• LUCAS OIL = / API SG / SF / CC / CD, JASO MA & JASO MA-2, ACEA A3
• SHELL = API SL, JASO MA2
• ROYAL PURPLE = JASO MA2 air-cooled and liquid-cooled 4-cycle engines / wet-clutch transmissions
• MOBIL = JASO MA /
• ADNOC = Prevents wet clutch slippage
• VICTORY OIL = API SL, JASO MA2
OK i voted AMSOIL + LUCAS + SHELL
Why do we not use Victory oil
Is it cause of the money
Are we that cheap
So how many thousands you paid for your bike and now you want to be cheap with oil
Do you have enough money saved up to pay the motor rebuild bill
Not one of the four motor tuners tell you not to use Victory oil
WooHoo
Cool, an oil thread, I've been waiting for one of these polls. Can't say I know to much to compare since I've only used one brand, heck I've only changed the oil one time and that was around 800 miles; but I used the reccomended Victory oil, and it's worked great ever since, so I'll choose that one. cheers
None of those...I use Aussie Penrite for Aussie conditions
Castrol ActEvo 4T Semi Synthetic 20/40
Exceeds API SG, JASO MA2
Got it locally for $7.50 a quart
Any JASO-MA or MA2 oil will do. I use Rotella T-6. Right now there is an $11 rebate for a gallon. That'll make it $4 a quart. Top that.
Yippee!!!! oil... lifeblood of the v-twins. Somebody here would put their brand in their coffee if they could. They carry a small vial in their pocket like whiskey. They use it like vitalis on their nappy heads. They check it before each ride and when they get home... make sure to add a drop if need be. Their motor only purrs with that special brand. Shifts gooder, better gas mileage, its liquid gold for crying out loud! Don't matter the cost. Change it every 3,000 religiously.
:crzy:cheers:ltr:
:crzy:cheers:ltr:
Everything is guna be alright....:eek:
Yup, 4 dollars a quart for diesel oil....thumb up
Aussie conditions, you have different air and a different sun? :D
I choose my brand because of Yankee conditions. :ltr:
Joking with ya buddy.
Name brand wet clutch compatible I voted for every one.
And your point is....? If you are being critical of Diesel oil, hey, its the same oil but with a heavier additive package that adds more engine protection. And that's a good thing.thumb up
I use Victory oil. Why you may ask? Because one night when I was sleeping, Ma Vic came to me on a Vision and told me too.
1 - 20 of 43 Posts
