1 - 15 of 15 Posts
OK, so I find that after more than 2+ hours in the saddle I get a really really sore arse…..so I am looking for a nice soft aftermarket seat (but here’s the catch) that I can keep my seat cowl on.
I know there are products out there but only want something that someone can highly recommend. Thanks guys.
some times its not the seat but the poshion we are in.
On some of my old bikes it didn't matter what seat I had. To me I think a firmer seat is the best
Yea Kris , you may want to look into bars or even peg position to cure your problem , to retain the seat cowl you will most likely be looking at reworking your original seat . I have been running my Flamed Bandit seat recently with comforting results , and it still looks Kool too !
OK thanks guys- good suggestions. Im glad no one recommended Burger King.
Maybe I can get my seat restuffed- will look into it.
For me, sweat plays a part in my derriere comfort. There are three things I found that helps.
1. Anti-Monkey Butt powder keeps you dry http://www.antimonkeybutt.com/. It available at different stores which are listed on their homepage
2. Bicyclist pants. Holds things in place and gives a bit of extra cushioning as well.
3. Bead Rider seat. Lets air between the motorcycle's seat and yours http://www.beadrider.com/.
Pro Pad also has a seat cushion that looks like it might be more comfortable but I've never used it so I can't give either a positive or negative recommendation http://www.thepropad.com/air-series-seat-pads/
Im just after better padding man......thanks tho.
+1 on going to a shop that customizes seats. That way you get it tailored to your butt and get the firmness or softness you want. I hope you don't have your wallet in your hip pocket and you're sitting on it. Lots of guys do and its a bad thing in a number of ways.
My arse would be sore too if I got to ride 12 months out of the year ....cheers
I , like most Hammer owners , wanted to keep the look of the stock seat....but needed a solution for a more comfy ride.
I would slide around too much on the stock seat, and would find myself always shifting / pulling myself towards the gas tank.
I have the touring seat....and like how it cradled my butt , and kept me much firmer in the seat pocket.
But I hated how it made the bike look.
So after some research , decided to have the stock seat reshaped.
I found meancitycycles.com ...and after emailing / talking with them, decided to send my stock seat to them to have it reshaped.
I wanted them to make the stock seat feel as close to the touring seat as possible......deeper in the seat pocket, with a firmer backing so I wouldn't slide back as much . They explained to me that with this seat....they do not have much to work with....but could definitely get me closer to what I wanted. Very decent people to deal with , and the turnaround was reasonable if you preset a date with them. Total price for me was under $150 , with shipping both ways.
Check out their site ...they have many different options / combinations of what can be done to most any seat. I went with a simple reshape / memory foam added.
The result .
Improved over stock.
The cowl portion untouched.
You would probably not know there was any work done to the seat at first glance ....by just looking at it , unless you had a stocker right next to it...then you would see a definite deeper cut in the seat.
Of course ...how it feels / works for me is the real benefit.
I haven't changed back to the touring seat since .....
I can ride comfortably , without stopping or soreness for the full 120 miles a full tank of gas gets me until the gas light comes on !!
Peter
The result .
Peter
That is exactly what Im after- thanks for your idea Peter.
Ive found a local guy who evidently is pretty good, but if it doesnt work out I will contact your guys. Shipping a seat from and to Sydney would almost pay for a holiday, so Im screwed in that sense.
Cool thanks Andy- great to know.
+1 on Meancityclyles, I plan on sending my seat in to get the Gel & memory foam padding done next week. PJrom Can you post a pic of the seat?
1 - 15 of 15 Posts
