1 - 18 of 18 Posts
I'm trying to remove the bezel from the speedometer. Not sure how to do it. Twist off or pry off. Don't want to break anything. Has anyone done this before.
2015 Gunner
I've also looked at the part schematic. Not clear how to remove the bezel. I've twisted it and it still doesn't come off. It's not a screw type thing. Still hoping someone has done this before
It's probably glued or sonic welded on. Why do you want to remove the bezel?
2015 Gunner
Here is the info I got when I asked the same question:
"Heat it and gently pry it off. Its glued on. Gotta be very careful though. Too much heat and you can mess up the bezel. Too little, and you can break it. Can't order just that part, so you'd need a whole new assembly if you broke it."
Now I was asking because I wanted it painted. I ended up having the entire speedometer cerakoted. Turned out great!
Pyro- got a pic?
You can see the bezel in this pic but the whole speedometer was cerakoted.
off topic- did you also tint your turn signals or did you buy new lenses. I recently saw where Ducati Monster replacements fit perfectly- and they are available in clear or smoked.
I bought the smoked Ducati Monster lenses from Amazon.
Pyro:
Thanks for the advice. I did as you said and was able to remove the bezel. I painted it black and put it back on. Looks good.
What did you use to reattach it? How difficult was removal?
It went on much easier than it came off. Removal was fairly easy once I put heat to it.
did you adhere it in place when you reinstalled it?
Discussion Starter #17
No. I was worried that I'd get it half on with some adhesive and then get it stuck in some awkward position. It's very snug. I may go back and put a couple drops of crazy glue on the seam between the bezel and the speedo.
1 - 18 of 18 Posts
