1 - 16 of 16 Posts
My speedo digital display is messed up. The far right side of the readout is gone. So now if is supposed to be a 0 it looks like a C - the far right line is not displaying....... anyone else have this prob?
I hope it does not continue to "degrade" or I will bee buying a new speedo.....
Question: If you replace the speedo will it still show current milage? I don't know if the bike computer stores that info or if it is in the speedo itself?
Is this for a Cross Roads?
Yes a 2010 XR. With 57,000 miles - still like new....except for this.
I've had my LCD items where the screen does exactly what you are describing. Could be bad electronics, moisture, etc. No way to know for sure until it's looked at.
Don't know about the odo thing...
Thanks for the reply. It's not just the odometer, it's the RPM, Voltage, miles, etc. I will live with it for now. Hopefully it won't continue to effect more of the LCD display.
I guess no one here knows if the computer or the speedo itself stores milage. I will look else where for that info.
Thanks again,
Don
I would imagine that your display is the same as mine, although different model bikes. I just had my inst cluster replaced under warranty. The mileage info is NOT stored anywhere and can NOT be reset in the new one. If you replace it, you'll be starting at 0, literally!!
Thanks for the info! I will keep my current speedo if the readout does not continue to fail....but was curious if it was storing or just displaying. Not to bad 57,000 miles and this is the only problem I've had with the bike.
And perhaps soon your bike will have 0 miles :)
G'day,
Vinish
There might be one way to adjust the mileage to what the existing speedo says and that is with the Digital Wrench the dealer has.
You could ask KevinX. I would not depend on a local dealer knowing unless they have dealt with this before.
Sadly; anything electrical or mechanical will wear out eventually. Sometimes prematurely like what is happening here.
I have had mine replaced TWICE on my 2010 XR.....
I asked the dealer whats up with that after the second time and he said just trey to keep the bike out of the weather....:(
I live in hot, rainy FL.....
Interesting....I will start throwing a white towel over it when parked in the sun. And a plastic bag when washing and rain - thanks for the info! What a PITA. Maybe Vic should address this, JK, never happen!
How far did the LED failure go on yours? More than the first right hand line?
Whenever I ride it and stop somewhere, I put my helmet over it...
Shouldn't have to do this sh!t....
Had exactly the same the day I went to take delivery of my XR from the Dealer... they had to replace the entire unit as it is sealed from VDO and No, the Mileage is not recoverable, you will need the Dealer to notate the current Mileage in the Owners Manual and on the Victory Dealer System for record purposes.
Mine both times just kept getting worse.
To the point where you couldn't read it.....
1 - 16 of 16 Posts
