1 - 3 of 3 Posts
I developed this weird squeaking noise under acceleration when I pulled the ole cross country out of storage. I went through and did a spring inspection and changed oil. Nothing seemed out of the ordinary and started noticing a weird squeaking but I'm not a hundred percent sure if it's coming from the motor or drive pulley or what. Has anybody notice something like that from their cross country or 106 and cured it? It only does it when it's cold and it sounds like it's coming from the right side. Any help would be great.. it's a 2012 XC with 23k on it.
Sent from my XT1585 using Tapatalk
I will check make sure it is, when I pulled it out of the garage I checked the tension and seemed on par but I'll take a closer look. Thanks. Hoping that's all it is!
1 - 3 of 3 Posts
