1 - 4 of 4 Posts
I got a great deal on some swept pipes, had them recoated and installed Thunder Monsters. The closest Vic dealer is about an hour away(mostly highway miles). Can I do the pipes,air filter, and unhook the O2 sensors and be safe riding it to the dealer for the reflash?
Has anybody ever checked A/F ratios with attached vs. unplugged O2 sensors??
You will be safe. Ride it clean and take er nice n easy. You can even run her strong but dont beat her. Listen for upshift popping and decel backfiring. If you dont have either then turn around and go home. O2's disconnected right?
You should be fine. All stage 1 does is in crease your rpm's by 500 and richen's up your fuel.
By disconnecting your 02's your have richened up your fuel.
Stage 1 will more then likely will not get rid off any popping.
1 - 4 of 4 Posts
