1 - 10 of 10 Posts
Any way to tell if my bike has stage one map without having to leave my bike at the shop for 3 weeks? I need to get rid of the map if I can.
2006 vegas 8 ball
hacker rippers
lloydz torque tubes
anger management fuel control
Judging by the add ons, if the bike isn't very lean my uneducated guess would be yes. At least a remap.
Why you worried about it?
Stage 1 is as sporty as a Vic ECU map gets. I wasn't worried, just curious as to why he feels the need to remove it if it exists. If he's going to add a fuel controller, it will alter any base ECU map to derive the proper injector command signals. I can't imagine why anyone would think they would need to remove a Stage 1 base map of a bike unless maybe they were going to put it back to its stock configuration i.e. stock pipes and air filter.
stage1
Just led to believe that I neede to clear the remap or it would run to lean (hacker instructions). You guys feel that unnecessary, thats good enough for me
Ya, I can't imagine it taking 3 weeks to remove it either. Wait,,,,,,is it a Vic dealer?! :ltr:
Seriously, check out WD to see if a tuner is there. It may be difficult even if you know what you are looking for. The install video will help with figuring out what you are looking for in a "tuner", a flash is different.
This won't be your bike, but should give an idea if a tuner is on it, what to look for. http://buywitchdoctors.com/p/1812/victory-motorcycle-parts-performance-featured-fuel-controller-sc-570/
Stage 1 map will run a bit more rich than a stock map. Aftermarket exhaust and breather should need at least that.
Good Luck.
sporatic miss
My bike had these symptoms before any add ons. The ams is for 07s and earlier.
sporatic miss
My bike had these symptoms before any add ons. The ams is for 07s and earlier. I appreciate your guys time
1 - 10 of 10 Posts
