1 - 6 of 6 Posts
I just installed the S&S airbox on my 06 Jackpot. Upon searching for downloads I have come across a stage 3 calibration for sale. The calibration part number doesnt match anything I have seen on these forums, so can anyone help in informing me if this will work ok on my Jackpot. I have rode the bike with no backfiring or popping so how would I know if need to reflash. Sure dont want to run it lean. The part number of the card is 801408207, It says Hammer drag stage 3.
Is this the same as the S&S 05 hammer download?
Discussion Starter #2 (Edited)
I forgot to mention there was another card also in the mix if anyone knows what that is. Part number 200353426 Have any idea what this is? I should add it had the K&N airfilter in it with Santa Rosa Aces pipes. Runs good I"m just am afraid it may be lean now.
To be honest, I have no clue what these "stage 1, 2, 3.....9" crap is. Instead of buying some used, corrupted cards off the internet and do the trial and error, you'd be better off getting a power commander and some dyno time
Stage 3 is for Victory S3 cams too. It probably won't be right for you. My bike was done with the Hammer S3 drag map and was rich as hell. Ended up doing a PCIII and getting the tune perfect on the dyno.
Thanks for your input. My confusion is that everyone says to use the 05 Hammer map with the S&S air filter withe pipes. I found this stage 3 kit with cal so I had hoped the cal would work.
1 - 6 of 6 Posts
