1 - 3 of 3 Posts
Thinking about doing two LED strips under the cheese wedges I drilled out.
Anyone know of the best place to grab a switched 12v+ cable and tap into it.. obviously i'll add a 5amp fuse. Do we have any accessory wiring "unused" near the seat area.. T-Taps would make life easy. A ground would be nice too but the frame would also work.
I really don't want to use a toggle switch, makes for a crappy looking/PITA install + a dedicated lead to the battery.
switch
Run to the auto zone. They make leads that go right on the fuse. Unplug attach and re install. Pretty easy.
Now for your switch. What i have done is take some thin pieces of aluminum. I have mounted it on a cold or screw either into controls or a bolt on my tripped trees. Run the wires through the factory loom. All hidden out of sight. So basically your making your own bracket. Get some spray paint sand it down pray it and your all set.
1 - 3 of 3 Posts
