I have a 2012 CrossRoads. Just noticed the tail light sometimes goes out on the bottom section so only the top 4 bulbs are lit. Probably something loose? It comes and goes. How hard is it to take the light apart and check?
It's not for the faint of heart. The tail light is sealed. I haven't taken one apart but I did read about someone who did using a heat gun along the seal to split it. There's a board in there with the LED lights. With luck it's a simply matter of finding a cracked solder and re-soldering it.
I also frequent a Wrangler TJ forum - there is a thread similar to this there and it has 1,000s of responses. You can get ideas and learn from what others are doing with their toys - so, lets see if it works here...
I'll start.
I installed the 1/4 turn throttle from Lloyds. I did not find...
Hello fellow vic lovers,
Decided to pull the trigger yesterday on a mustang vintage seat with backrest for 350.
Who has it and what's your take. I knew I would not like the stock seat and I have never liked any one of the 6 I've had on different bikes. I usually just go to KnoPlace upholstery...
Hello all!
I've got two seats for my XC - a touring seat and a tooling around town seat. Does anyone have a recommendation on storing the seat not in use? I have a bracket for the tour pack that works well for that, but I was wondering if anyone had a ready made bracket for hanging the seat...
Hi, I notice that the rear seat I just got used didn’t come with the plastic bushings that need to go on my 2016 XC saddlebag support bars to stop the seat from sliding side to side and rattling around. 2 are needed on each connection point (a flanged and non-flanged one at each). Anyone had any...
Today my cruise control stopped working. While travelling at a constant speed in 5th gear at about 55 mph, I pressed the "on" button. I got the momentary green flash of the cruise icon on the dash like normal. I then pressed the "set" button and nothing happened. The green cruise icon did...
