1 - 6 of 6 Posts
I have a 08 Kingpin that the led tail light has gone out ,that part is now discontinued. I’ve been searching to replace light with one that has the tag holder on it. All the ones I’ve seen has the 3 wire hookup.Is there an adapter for this to connect light with wiring harness? Need suggestions please.Thanks in advance.
sounds like your guessing at the wires. Go to auto store walmart buy a multimeter to test wires for what does what. Never trust victory and there colors cause it can ge a ground wire being pink not black
Say look up Paulie at Honda east maybe he can find you a light
Witchdoctors.com has an adapter to run a 12 volt victory led tail light. The 12 volt one is still available from Polaris any servicing victory dealer can get the tail light. Or you can order the same tail light from witch doctors also.
dodgecharger
you have to go to kingpin forum if you want to give him the information
1 - 6 of 6 Posts
