ok got another flat, this getting old and expensive, I need to take off the rear tire, first sep loosen the nut on left side THEN what? if you jack it up with this loose the axle? Whats the correct way to take the tire off... David [email protected]
yeah it does come out the exhaust side. i have swept pipes so i forgot about removing the exhaust. if you have stock pipes you can just remove the mufflers. pretty sure just removing one will work.which side does the axle come out? seems like it would come out the muffler side BUT hope not. Thanks david
