1 - 18 of 18 Posts
searched in vain for info on fuel/gas tank risers or my XC
1. what do they do? any proof?
2. how much$, and where do ya gettem?
3. can they be made at home?
thanks
thanks
1) Were sold primarily as an appearance item. Raising the tank had better lines according to those who like them. They do increase the space under the tank and theoretically provide more air but I don't think anyone showed a measurable difference.
2) As far as I remember they were designed and sold by Bad Ace. Bad Ace appears to have fallen apart. I did see these on eBay - https://www.ebay.com/itm/1Pair-Gas-Flue-Tank-Lift-Spacers-Kit-For-Victory-Hardball-Cross-Country-Roads/222860150170?epid=11011629788&hash=item33e380059a. I do not own them so I can't speak to these.
3) Probably but not at the cost you'll find on eBay.
thanks mate, link wont work for me...
anyone else have anything to say about XC Tank Risers?
A while back someone reported they don't make a lick of improvement in the git up and go department. And some say they hear the intake after installing them. I have no first hand experience with them, just what I read.
They're mainly for esthetics, I have then on mine and really like the look. I have a good amount of motor work and can say they dont do much for preformance but it does let you hear the intake suction a bit more. Personaly I recomend them but I did buy the cover for the throttle body/linkage behind the right side cheese wedge. That would be the only down side is with out the cover (I think from vic baggers) it showed the throttle body and linkage. Also on the upside it seems like I can get a bit more fuel in the tank cause of how it raises it, but that could be me imaging that.
got a pic for us?
got a pic for us?
Ill try but my bike at the moment has no faring on it so its hard to tell the difference, and I didn't take any before pics.
Pics of tank risers and TB linkage cover
Here are some pics hope you can see what you're hoping to see. If i remember when I get her all back together I'll upload more.
Hi WoodRat, looks like it would be easier to replace a broken clutch cable at the side of the road with the tank risers in too. Gotta beat finishing a long trip with vicegrips clamped on the clutch throwout arm.
I gather they must go on like this to actually raise the tank?
Just starting on the cams pipes and intake and sorta fitting the risers now so I dont forget em😉
I might just have to go the the machine shop and make me a set. Looks easy enough.
Yep, very easy install. If you have someone help you I dont think the tank even needs to get fully pulled off. I did mine when I cleaned my air cleaner so the tank was off.
Discussion Starter #17
did the cams and filter last night so mine was off😎
do make sure you put them on the correct sides. i didnt and fussed and cussed because i had to do it more than 1 time.
1 - 18 of 18 Posts
