1 - 12 of 12 Posts
Anyone know where the temperature sensor is located on a 2010 Victory Cross Country.......Thanx
For the outside air temp.....Thanx
if you had the speedo upgarde it is put inside the h/l housing.
--irv
Irv- I have a Cross Country, so it's already there.
oops! brain fade.read it .didnt digest it.
Not a problem, I have been known to incur numerous brain farts everyday. As per my wife !!!!!!!!!!!
Thanx, appreciate the info.
and i learned something new too. thanks kevin. i figured all cross bikes
put it in the same spot.--irv
If you find it and pull it out and drop it just below the faring you'll have accurate reading.
You'll all so find out most bank temps are way off
I _might_ have to look into how hard that is to do. Mine was reading 109 yesterday.....it was nowhere near 109.....
1 - 12 of 12 Posts
