1 - 10 of 10 Posts
....when winter shows up. Or,. How I learned to love the "upgrade" season. I could not decide between the titles so I'm just going to run with it.
So last summer I added a few things to my Gunner, and got it on a dyno for a base line run. Having Lloydz Torque Tubes, Adj. Timing Gear (+4), Trask 2 into 1 exhaust, PCV w/AT got me spinning the roller with 102hp/117tq last August.
Putting the bike away for winter I got busy with a few other minor upgrades to my Gunner's little 106" motor.
- Maxbore 49mm throttle body
- ECM flashed to remove speed limiter and raise redline rpm.
- swapped out the stock cam carriers for clearanced ones.
- installed Lloydz .495's in clearanced carriers
- sent my heads down to Star Racing for them to port & polish, do a three angle valve job, install high lift springs & low profile guides, make and install oversized intake valves
- got a pair of Lloydz high compression (10.4:1) pistons
While not a engine modification I did order a set of FMB Phatty Phat bars (12") for my bike. Once I figured out the harness connector runing the wires internally was simple to do.
And at some point before this all goes back together I am upgrading my clutch to almost all Barnett stuff.
This bike is going to be a lot of fun this coming summer.
Exciting stuff! Can't wait to hear about it when you get it back together.
Got any pictures you could show us? :grin
I do,. But I am currently forum stupid on getting those pictures here. Or actually getting them back on my iPhone.
Once I stand up and hear a loud pop I will post what I got so far.
Sounds good to me, no rush.
Got the heads back today,. Here are some pictures.
Alright now get that bike back together and start saving up for new rear tires :devil
1 - 10 of 10 Posts
